Ashtray light replacement
Houston
I'm switching some interior lights and I got stuck with the ashtray light, how do you access it? I removed the ashtray itself, but it send the light is behind the assembly that holds it in. Any help would be appreciated.
Oh, it's a 03 lc.
The trim piece that surrounds the ash tray and 2 outlets pops right out. I removed that piece after removing the center console cover that goes around the shifters - which is also an easy :banana: job - however I am not sure if removing the center console is necessary. It definitely makes the disassembly & reassembly easier though. That surround is held in by a couple clips along the top and around the edges. Just get a small flat head screw driver with electrical tape covering the end (or preferably trim-removal tools if you have them) and gently pry away at it. Once the clips come loose just disconnect the wires to the outlets and you can pull it all the way off. You will see the light bulb for the ash tray. It's an easy job I promise!
