ARB wiring helping
I'm installing an ARB compressor. Everything is finished except the ignition wire and illumination wire. I need to know where to tap into those wires. My switch is installed next to my transfer case shifter. What wires can I tap into in that center area? Seat heaters? Cigar lighter? What color are the wires? Thanks
What year and model?
You can grab both from the seat heater switch. You'll have to use the EWD or your tester to find the wires.
That's why I installed my switches near the rear window vent switches on the left of the steering wheel. Tapped into them. Viola.
Same exists from seat heater switches. I'd look on the manual but iphone is not easy to use.
White-Green stripe off cigar lighter for illumination and Gray for power...from 2004 EWD.
