ARB Twin Compressor wiring to two different batteries?
Hmm, some examples of what can go wrong:
-using a 10-20A DC-DC charger would not be able to replenish the aux battery as fast as the compressor can discharge
-having the Aux battery located in the trailer will also charge slowly if hooked up the way most people hook it up (no trailer mounted DC-DC charger).
-using a voltage sensing dual battery isolator.... where it disconnects the aux battery if it detects low voltage on the main battery (i.e. 12.7V). A large compressor could conceivably cause this condition with a marginally performing alternator set-up.
Job done, pretty happy with the result.
hcdZnj083ESZ4Gt_JLPNrkRt0d3_fhoF88ZCl0QSAhy7B0OUyDblgTSfjmogBhVoednod45pwKuEHTiwDkgCHRmmH1t2jUhE_61Law3QdWxACiYLDgNx_vmmQBLQqu56pvx_faTCZOMTA_n0VefWmWHsczlHYy4_RX17iLRe6UjTIK2ASO5wAe03kkDBoR_4RAxhhHQyOrEPbp1El7Xnkv-cJamlSZLY7ETxFo8Bu618lwuf9YnAnQwKj2ibya_Oi8kW6RwBHykN69_egGR90kZdpdLwZboQTpJwh0BwLXByQvlWXFmzN5V-K67EUxXdX_argJymcRRDQQjB7hel4ZtVqMCBda4l43KzPBfaDTzXs3WYHnbtzeF2wMC1FCxTIMrSrHP06bVB_aKsPp6LmgTLMHwL0br2y2C8k_7E5vrkWVxtROVAMrcvvXywzAoaKOQQEBKJoBqb7i4iR_LssV6dZARfNyh7VribupfDuhY8G4EKLecAoe2blZroabYp5SLFDRVYon8TPjKcaXghyYpBNvSQfK79N8nI-mpehNwDUlbO3dBTojTcI8obUQcofr27Xdy113V49LI1Kl00TxUmPOAerVsDgCvzItGJlv-In0bf5uVkiOVxPtXNCPwW7qhqRIhLipargkDFjGGTXqJCeHoBXQKimvkJtwDWCd7t4RcTaf_6QMnpFIjhXqVwBTCl69D0ADuDXuQfswdueBvYCA=w736-h1307-no
That backing plate is very good fore thought to avoid stressing the plastic inside that cubby every time you couple/uncouple your hose, especially if you're trying to attach/detach the hose when under pressure.
