ARB Thrust washer-where can I get one
I was installing a arb in the rear of my fj60 axle and I screwed up the thrust washer when putting in the cross shaft. Now I need to find where I can get a new thrust washer. The Locker is a RD 124 I believe, the older version. Anyone know where I can get them and how much they cost.
A R B <---- this is a link
This is their phone number: 425 264 1391
You are going to need:
QTY- 1 Part number- 151102 Thrust washer
You will also need, because you are required to remove the piston cap from the locker body in order to replace the damaged spider pinion thrust washer:
QTY- 6 Part number- 200205 Cylinder cap bolts, 8mm
QTY- 6 Part number- 150401 8mm Cyl cap bolt lock tab
QTY- 2 Part number- 200207 cylinder cap bolts, 6mm
QTY- 2 Part number- 150402 6mm Cyl cap bolt lock tab
These bolts and lock tabs must be replaced whenever they are removed.
RD124.pdf <---- this is a link
:beer:
