i'm too poor to afford arbs, so i've got no experience...just trying to get the raffle rig together and getting a bit frustrated.
when the diffs for the raffle rig got built, they installed the thrust block and spider block. problem is, i have to get them out to measure for c clips and to install clips.
how do you get the spider block off the short cross shaft?
also, is the long shaft supposed to be kinda a bitch to get out? i'm used to stock where you pull the pin and the shaft falls out.
