A while back I had front and rear ARB air lockers installed as well as the ARB CKMA12 high capacity compressor (Not the new high CFM model). When I would go to lock the diffs I would:
-Turn on air compressor (hear compressor motor for 1-2 seconds)
-Turn on rear locker (hear compressor motor for about 1/2 a second)
-Turn on front locker (hear compressor motor for about 1/2 a second
If both diffs were locked for an extended length of time (3-5 min), you would hear the compressor kick on for about 1/2 a second every 3/5 minutes. I am assuming this is normal operation.
On to the issue...
A few weeks ago the front locker stopped functioning. I could power the compressor, engage the rear locker but when I would hit the switch for the front, the compressor would just stay on. I assumed I had a leak, kept the front locker switch in the OFF position and only used the rear.
I finally got around to looking at it today and upon checking for snugness of the brass fitting that houses the air line connected to the diff, I gently tugged at the air line and it popped right out. I went to a hardware store, got a new ferrule, reassembled the fitting and reattached it to the diff. During the entire repair I referenced the installation manual provided by ARB.
Here is the "issue". Now when I engage the lockers I:
-Turn on rear locker (hear compressor for about 1/2 a second)
-Turn on front locker (no sound)
-Turn front locker off then back on (hear compressor for about 1/2 a second)
I thought it odd that I now have to play with the locker switch to get the compressor to kick in. To further test the system I connected my auxiliary air fill up hose (so that I could drop the compressor pressure on-demand) and repeatedly tried the full cycle of getting both front and rear lockers to engage. The front locker consistently required two or more on/off cycles in order to get the compressor motor to turn on. On the third test cycle, I experienced the same issue with the rear locker. I turn the compressor on, hit the rear locker switch and nothing. I rocked the switch back and forth and it turned on the air compressor.
One of my questions is, if I had a small air leak since day one (which I am assuming I did since the blue air line came out of it's fitting with next to no effort), does a fully operational front/rear ARB air locker system ALWAYS cause the compressor to turn on when flipping the buttons for the rear and front?
I am not 100% certain that I actually have a "problem" yet. All of my testing was conducted with engine on in park. I never moved the vehicle during locker testing so that I could hear the click of the lockers engaging. I'd like to hear some feedback from those of you with the same setup so that I know what "normal operation" is.
On to the issue...
