LINUS
Waiting for the Great Pumpkin
Thank you Linus, that would be great! Low profile might work better for me. But how strong is that bumper? Do you think you can take a whitetail at 55?
Sorry late followup:
From the center sheetmetal under the grill to the outer rubber pad of my layflat link is exactly 12”.
—So roughly 7” more than a stock bumper if they are ~5” thick going from memory.
The layflat is 1.75” including rubber pads both sides (from Factor 55).
My Hawse is a fairly thin 5/8” offset one (from Slee).
So combined max of 2 3/8” of “poke” over the bumper with the roller fairlead upper ground off.
So even buying a winchless ARB bumper is going to stick out shy 10” (9 5/8” is my exact, but expect small deviation) -from that thin sheetmetal lower of the grill dead center.
—As to amount of protection, I say you’re better off mitigating with the hoop and expect a better chance of saving the radiator & having at least one headlight to “limp home” & no holes in the radiator/leaking coolant -with. If a buck can stuff a few points from its’ rack in the raditor, then it was just bad luck. But at least a doe would have to use a hoof or skull.
—Morbid, but realistic.
But beyond that, the ARB is thin overall compared to some on the market (Slee Shortbus is my favorite that is non-hooped) - but they aren’t a full hoop nor will hold a M12K.
I’ve said it plenty, -if the Slee Shortbus would hold a M12K, I’d fab my own taller hoop. It’s thicker built, as what was mentioned of the wings/endcaps of the ARB can fold easier than the top-tier bumpers.
But a bent ARB you drive home on is still money very well spent IMO. And a winch to at a minimum retrieve yourself or a buddy is smart $$ too.
Esp if snow & your 80 will ever be face-to-face.
HTH.
