I hate to beat a dead horse, did you meter all 3 of the fusible links? When my harness went (on top of a mountain), it blew one of the links two were good.
1994
Air Flow Meter
Toyota Land Cruiser 4.5 A 804903 $Call A-1 Auto Salvage USA-NM(Kirtland) E-mail 1-505-325-1994
1993
Air Flow Meter
Toyota Land Cruiser SLV,4.5,AT, C 029956 $Call Highway 64 Truck and Auto Salvage USA-NM(Kirtland) Request_Quote 1-866-334-5092 Request_Insurance_Quote
Thanks Landtank!!!!!!!
ECM SEEMS to be fine. I unplugged the TP and VAF and my check light came back on!!! Then plugged in the TP and check light still on, then VAF and it all went bad, no check light. So I checked voltage on the VCC and with the VAF unplugged, I had 5 good volts at the ECM and at the VAF plug. Once I plugged in the VAF, the voltage went out, both at the ECM and at the VAF plug. So I started doing ohm checks on the VCC line. With the ECM unplugged, VAF unplugged, and TP plugged in the resistance in the VCC line was about 3K ohms, normal. I then plugged in the VAF and the resistance went totally haywire. This indicates that the VAF went bad and has grounded out the VCC line inside the VAF somewhere. So I am now searching local yards for used VAF.
Does anyone know if the VAF on the LC was used on any other Yota's?????? It's hard to find LC's here in New Mexico.
Congrats dude, you deserve a nice reward for powering your way through the electrical troubleshooting steps!
Hopefully we'll meet up some day on the trail.
Landtank is the man.
Thanks
Hey, I'll PM you the next time I plan a little wheeling adventure. How's your rig set up? Lift and tires? There's some great stuff between ABQ + SF. From mild to hold on to your shorts!
I think I have a similar issue with my '97 lx450. The shop can't figure it out and wants to get an ECM for it. What is a VAF and TP that you're referring to and what plug is it on the output of the ECM? Thanks,
Chris
