I'd like to borrow this socket if possible. Glad to give you what a new one costs to insure its return. Lemme know.
So, as I said I never need it... tonight I had to use. LOL. It was TIGHT.
Sheered my hub studs this weekend and was able to get 4 out. 2 won't budge, even breaking a medium sized easy out in one drilled hole. So I removed the hub, it's going to a drill press tomorrow. That'll learn it.
I have to drill out the dowels as well. I'm going to tap the 4 spaces and run grade 10 bolts in those spots around the existing new 6 studs. Can't do all six locations since there are extracting holes that are off-center in those spots. Dang it.
Sounds like fun....not!
Is it worth putting small tacks on the stud and building it up till you can weld a nut on and back it out? The heat from the weld should loosen it up. Tight space though.
Did the broken easy out come out?
no sir. Broke clean even. Can't get nothing on it.
