anybody used/knows the Warn HD snatch block (the red ones)
e9999
Gotta get out there...
Moderator
US
about to get a snatch block. I need at least 24000 lbs rating. Wondering about the Warn ones. The HD red ones look completely different than the usual twist open blocks a la ARB, TMax etc. Doesn't look as easy to open, is not rated higher and is much more expensive (Warn 24000 $150 vs ARB 30000 $70 and less for other brands).
What am I missing here? Surely it's not just the name. Is the difference in cost because of some significant advantage? What? They sort of look stronger but I guess it's the rating that matters.
How easy are these things to open and use?
Can you use a big shackle with them or do they get in the way?
Really hard to tell from the Warn photos....
TIA
added: this is the one I mean: http://warnindustries.com/truck/accessories/snatch_blocks.shtml
compared to this: http://www.amazon.com/ARB-Snatch-Bl..._1_1/102-7712169-7612902?ie=UTF8&s=automotive
I have one, Dam thing weigs a ton. Actually, other than the weight they are just as easy to open/operate as the flat plate ones..
I got mine just because of line size (over 1/2")
My ARB works just fine...
how does it open?
does it seem stronger or better somehow?
looks to me like there is a pin similar to this:
on the backside of the D-ring here
and you probably pull that out, flip up the D-ring gizmo, and flip open the block
that's how I'd see it working
yes, talked to Warn. There is a springy bit on one of the pins.
Never got a good answer as to why they use that design rather than the flat side ones...
check out rockstomper.com
I get all my recovery gear from these guys. no affiliation, just a happy customer. When I called them, it was just after I got my winch and I had lots of questions about this stuff. they were knowledgable, friendly and just plain cool.
They have their own snatch block - it's what I have.
oh and by the way, had lots of fun in SB. thanks for the insider tips - my in-laws were quite impresssed.
heh my snatch block is an REI special! rated for 24,000 lb tho! think it cost me 28$
