bjowett
Supporting Vendor
As TeCKis300 mentioned above, the 2007+ Tundra plows will work. The mounting bracket may require a little reworking depending on brand/how it mounts along the sides of the frame. The LC is heavily built, the front end can take it.... just don't be aggressive or stupid with it (ramming snow banks). The only limitation over the Tundra, is the shorter wheelbase, which of course is an advantage when maneuvering. Something mid duty up to 7.5' and maybe 550+lbs is the practical limit. Though at this weight, it will require heavier springs and/or a Timbren type bump stop. Most plow manufacturers will not recommend their mid duty plows, but many will fit if the mounting bracket is compatible.
