So, the Cruiser started low idling and stalling and stumbling this morning, and searching reveals that the Idle Air Control Valve (IACV) is probably gummed up, which after 226k would seem to make sense.
Called the dealer, and the Toyota part is NLA, and they're pricey when found elsewhere on the interwebz, from 240-500 bucks. Anyway, evilBay has a number of "remanufactured" options for a fraction of the price, has anyone tried them, and your results?
22270-66010 Idle Air Control Valve Connector Toyota Land Cruiser Lexus 4.5L | eBay
22270-66010 Idle Air Control Valve Connector For Toyota Land Cruiser Lexus 4.5L | eBay
As far as shade tree mechanic-in', I ordered 2 new o-rings from the dealer, and will pull the valve and attempt to clean it with carb cleaner and shoot the contacts with electronics cleaner for good measure. Anything else I should try, I mean other than the usual MUD preventative head gasket replacement???
Also, my bucket has recent tune-up, new oxygen sensors (Toyota, per Mudrak), new PCV valve and runs fine otherwise, save for the gas tank 'whoosh' at fill-up, which appears to only be remedied by installing a new charcoal canister, which I plan to do - but not sure if these issues would be in any way related.
Any input on this from the hive mind? TIA, this forum is truly amazing.
~ Bill
Quick update: just went out and started, let idle for a few minutes, revs went to 1400 +/- at cold start and progressively dropped as the thing warmed up. No CEL, so lends credence to air leak somewhere...
~ Bill
