I am hoping this isn't as bad as it sounds and any advice / help is much appreciated. I up shifted into 2nd gear and accelerated then approaching a stop decelerated and it sounded and felt like it was chewing gears and slipping. It drives fine on the upshift and if you engage the clutch and brake, no problem. The banging and grinding seems to be on the second gear deceleration. I am hoping it is low trans fluid, low transfer case fluid ... something simple...but.... any way thanks for any info.
