Any interest in an auxiliary AC condenser fan kit?
Mandrake
Supporting Vendor
South Ogden, UT
Hi guys.
I've been trying out different fans for the AC condenser for a few months and finally landed on something that works really well, even with my modded blue fan clutch. What I have going on would be a complete bolt in with zero cutting or grinding, no zip ties through the condenser, and wouldn't require any cutting or splicing into any existing wiring.
I know Landcruiser Phil was making a kit for a while but it sounds like they're NLA and if there's a desire for these, I'd be happy to become a supporting vender and put some kits together.
No pics yet because everything's temped in right now and I'm still sussing out two of the mounts. Price is TBD. More details regarding features and setup will follow if there's interest.
I'm interested in knowing the specifics. It's a punch in the gut watching my temps rise in stop-and-go traffic, having to turn off the A/C just to keep temps in check, after practically replacing every cooling component.
I hope to see your kit but I am running the Toyota AUX A/C fan.
I am not sure how many people know, but the Toyota AUX A/C fan can be purchased online: 88590-60010
It bolts right in, but does need to be wired.
Any idea how many CFM that moves? The fan I'm using is 1000 CFM and with the engine off, I can feel it moving air all the way back at the rear exhaust manifold.
As was said in the LCP thread about his fan, this is not meant to correct any engine cooling issues. It is only meant to keep air moving through the AC condenser so the vent temps don't rise when going slow or at a stop. If you have to turn your AC off to keep engine temps in check, you still have an issue but if you've replaced everything, I'd say try a modded blue fan clutch. The way I see it, that's the best way to bullet proof the engine cooling system on these trucks... once everything else is in order.
No idea, but it is kept in stock at a parts supplier that is surrounded by desert...
I’d definitely be interested in a new fan kit. I had an LCP fan kit but I didn’t notice an improvement in AC so I got rid of it. I have since replaced all of my AC components and I’d like to give one another try.
I have zero experience with the LCP kit, but it uses what looks to be the same fan as my Sequoia and the fan I'm using on my 80 moves a LOT more air than that fan in the Sequoia. Let me finish mine up and crunch the numbers, get a supporting vender status, then we can talk prices and whatnot.
*edit- I too replaced all my AC components, so I essentially have a new AC system (plus a modded blue fan clutch) that this electric fan is making an improvement on.
Sounds good. I don’t think there was anything wrong with the LCP kit. It would have probably worked great if it was on a properly functioning AC system. Let me know whenever you’re ready. Thanks
It's about 95 and sunny today and I had some free time, so I took the chance to go out and get some empirical data. I'll need to go back out tomorrow to run the same route and speeds again, but without the fan on to get a baseline. BUT... here's what I have for now with the fan on.
The truck has a new condenser, evaporator, compressor, expansion valve, and receiver/dryer as of about 600 miles ago, and has a modded blue fan clutch. The truck's been sitting in the sun all day and I went out at 3:30 to start the test. The windows stayed up, and the HVAC settings the entire time were: vent/feet, recirculating, fan on full. Temp measurements were taken from the middle dash vent.
-It was 128° in the vent before I started the engine, and it took 1:15 to get down to 70° in the vent with the truck at idle and in my driveway.
-From there, driving around the neighborhood at 20-25 MPH took it down to between 51° and 53° initially and got to that temp in 43 seconds.
-Stopping for two minutes to simulate a long light made it climb to 56°.
-10 MPH @ 1500 RPM (approximating the average RPM I run trails at) got it down to 48°.
-Another 2 minute stop to simulate getting out of the truck or waiting for someone to clear an obstacle took it back up to 56°.
-Back to 10 MPH @ 1500 RPM brought it back down to 48°.
Anyway there you have it. I'm not sure how these compare to what the other fans on the market do, but the seat of the pants tells me that there's probably a 5° to 10° drop in temps at low speeds compared to what it was like before I put the fan in. And as an aside, I saw 43° on the highway at 70 MPH. Brrr!
All right, got back from testing without the fan on. Same conditions and ambient temps as yesterday...
-128° to 70° took 1:43 (28 seconds longer)
-55° to 58° around the neighborhood (4° to 5* hotter)
-60° after a two minute stop (4° hotter)
-54° 10 MPH @ 1500 RPM. (6° hotter)
These numbers were roughly what I thought they'd be. While they're all mid single digits and I know that doesn't sound like much, the seat of the pants feel is very noticeable. Here's a shot of the setup. The wiring is still just crap wire I had laying around and is loosely zip tied in. I'm a retired aircraft electrician; I can do far, far better when I want to. ;)
I've had the OEM JDM fan on my rig for quite a while now, but after upgrading to a modded blue fan clutch, I've found it to be unnecessary even on the hottest of Florida's Summer days
In fact the blue FC will move so much air that it will suck spin the unpowered JDM fan
I'm glad the modded BFC is working out for you, especially down there in FL. I grew up in Bradenton, so I know the struggle with heat and humidity.
I have the same clutch in mine and like you said- it spins the aux fan pretty quickly. My wife joked that I could use it as a generator. I've seen others say that these fans that have been used in other setups don't make a difference once you go to a modded BFC, and that makes me think that the fan I'm using moves a lot more air than the JDM fan and the Denso 100 series fan because as mentioned in my previous post, I'm seeing an approximate 10% reduction in temps on top of what the modded BFC provides. The fan I'm using is advertised at 1000 CFM... no idea what these other fans being used put out, though.
I have two local 80 guys that are willing to do some beta testing for me so I made up a couple more sets of brackets.
There is a lot of adjustment available in the blue clutch, both with regard to the engagement point, and the viscosity of fluid people use. I've also heard multiple times that they don't necessarily come from the factory adjusted to the same point, so two guys who bought new blue clutches and swapped in the same fluid, don't necessarily have the same the same engagement.
Personally, I think there's a misconception about how much engine power it takes to run the stock fan. I can FEEL the difference on hot days, and I know for a fact that some on here have their clutch adjusted more aggressively than mine. The idea is that the electric fan is supposed to operate entirely based on AC performance, kicking in when the AC needs it. If your clutch fan is adjusted to the point where it's running constantly (and therefore always cooling your AC), your clutch fan is adjusted to come on sooner than needed and you're wasting fuel pushing a fan when it's unnecessary. Just my opinion, and it's worth what you paid for it.
@Mandrake
Just giving it the calibrated eyeball, that fan you're using seems to have heavier wiring than the OEM fan. No telling for sure, but one would assume that means it draws more current and therefore moves more air, but it's hard to say for sure.
I bought a new Aisin and followed the directions Landtank posted and noticed an improvement in AC performance over the stock clutch. I think we're on the same page with the fan clutch and its function, and what purpose the engine driven fan serves vs. an electric AC fan.
I haven't measured how many amps the fan pulls, but it blew a 10A fuse. 15A has been doing the trick, so I guess somewhere between the two.
for all the folks who have replaced all the cooling parts including a blue fan clutch, dont forget to change out the $57.00 fan. Mine exploded, it's the only thing I didn't replace and it just cost me $1,200 to replace all the cooling components again.
What, not using the stock CDS fan relay and fuse location?
Honestly, if I were making a kit, I probably wouldn't either. Installing the contacts and wiring inside the stock fuse box is non-trivial, but if feels like the slickest possible option.
