- Thread starter
- #41
I assume you got diff fluid, but you didn't specifically mention it. As far as the moly you only need 2-3 tubs/tubes for the birfs only. The knuckle bearings and wheel bearings all use wheel bearing grease. Mobil1 is good but I've also used Valvoline (import type).
I would assume the wheel bearings from Autozone will be Timken which are fine.
You will probably want 2 drain pans to catch diff fluid and grease. I can bring one if you need it.
I have one drain pan so if you can bring another, that would be great.
I did miss the diff fluid, how did I miss that in the threads. I guess I better go back and re-read them. But, in any event, I'll pick up some diff fluid on the way home tonight. Thanks for catching that...
