Any good radiator recommendations?
Southwest Oregon
Well, it's been a long time since I had to buy a radiator for a 60.. it looks like OEM is history and a copper and brass is 4-600$ for a 4 row... I am in Oregon, any tips? I have avoided aluminum- I can fix/solder copper/brass.. TIA- this is for an 84 fj60
Times 2 on CSF. Over 15years of use in my 87, hot, humid weather. Zero issues. Not cheap, but nothing really is anymore.
3X on CSF radiator.
It is so identical to the original Toyota radiator in every possible microscopic detail that I believe CSF was making them originally for Toyota
3X on CSF radiator.
Except for the fill neck. Toyota neck was a nice curved piece the CSF has a right angle bend. I have 2 CSF radiators installed and both have a slight down angle on the fill neck that is an issue with ability to fully fill the radiator. That's my only complaint and when the time comes I'll likely replace with CSF.
replaced my radiator with the CSF, couldn't be happier. be sure to save the fan shroud
Well, I am not sure if I still have one- this rig is a project that I am finally getting around to. But thanks for the reminder! I will figure something out..
I keep forgetting it's an 84 on an 89 frame with a 6AT.. I could go non stock radiator but I don't want to fan too much.. I will probably have to fab a shrowd.
