So I reinstalled my 4 speed today and discovered a problem.
When I pulled it I pulled it with the motor and tranny all as a unit. I put the motor back in and then replaced some seals in the tranny and put on Poser's t-case saver. I started to put the XMSN back in and it just would not go with the emergency brake drum in place due to the way the PO had cut and turned the torque bar so I took it back off and got the tranny back in. Well, the drum won't go due to clearance either. I can deal with that - I can tilt the motor, pull the tranny back a 1/2 inch and turn it so the emergency brake is a bit below the cross member or take it all out to put it back in, but...
I understand from reading MUD that once the torque tube has been cut, rotated and welded it really no longer serves any purpose other then another crossmember. I know some folks have completely removed theirs and others have replaced them with other cross members for their specific application.
Is there a prefabbed bolt in solution?
If not, I am interested in pics of bolt in solutions that others have built.
I like the idea of having something in the middle even if it no longer serve the anti-torque purpose.
