So, I am trying to help my in-laws out with determining what they need to allow them to flat tow their 2010 automatic FJC.
I found the following at Remco's website:
They no longer manufacture or sell drive line disconnects but still indicate that a drive line disconnect may be required. I have read through a ton of past and closed threads regarding the need for the disconnect on the front prop shaft, so I am not trying to debate the need but I am trying to find out if the reason for Remco's change is due to failures or litigation from owner's rig failures.
Also, I noticed several options on their website for tail light wiring kits ranging from $110 to $180. Help here in determining what is needed would be great.
One last item: FJC front bumper - Most of the rigs have had the ARB combo bumper used. Is there any reason why a different bumper could not be used? Also, can it be a winch bumper or does the winch get in the way of base plate attachment?
Here is the info I got from Remco's website for anyone wanting information for flat towing their FJC:
Components Needed to flat tow the FJ-Cruiser:
Found this on www.remcoindustries.com/Towing/Store.php
Front Propeller shaft disconnect: Call Melinda at Southwest Drivelines (928-782-3611) or David at Drive Shaft King (800-442-6329).
Base Plates – Blue OX BX3768 - $430.00
Braking System – Blue OX Patriot Brake System (PN 10050000) - $1395.00
Safety Cable Kit – Blue OX Safety Cable Kit, Class IV, (PN 10020028) - $100.00
Tail Light Wiring Kit – There are several options here ranging between $120 and $180.
Tow Bars – Blue Ox Aventa LX Class IV, Ball Swivel (PN 10020037) - $845.00
Thanks!
Thanks!
