Another DIY shop press brake
Almost done with mine.. A little more progress today. Need to finish welding and add stiffeners here and there.
J
can one do repeatable clean intermediate angles with those or is it only good for 90deg?
I can bend pretty much any angle with this. It takes a little to repeat, as this is a 90% manual operation. I use a digital angle finder as well. It would be nice to have a backgauge for a faster set up on multiple repeat production.
I use a 3" V-die so I can bend thicker material with less tonnage, but gives up the sharper bend/edge. Once I get the remainder welded out I may change to a 1 1/2" or 2" V-die and either add another jack or just limit my width/thickness of materials.
J
I see other guys tossing in a solid dowel to accomplish this.
Yes, I've seen this and looks to work pretty well. I have several sizes of bar stock to choose from in the shop. Just need to play around with it. I was just going to build up a piece of angle iron to lay directly into the 3" angle that I have now.
J
curious about all this...
would it make sense -subsequent strength wise- to heat up the plates just before bending them?
FIY Fastenal is having a good clearance sale on flat bar in alum, stainless and hot rolled. Bought 1/2"x4" for 25 cents an inch.
Just use "clearance items" in the search box and then pick your poison. Scored some other stuff too, taps, bolts, inline fuses, mega 200A are going for just over $2
OK, but was thinking along the lines of a torch... Can't be that bad
What kind of torch?
It doesn't take a lot of energy to make a 14 gauge piece of steel glow, but to make a 3/16, 1/4 or 3/8" sheet glow takes a bunch more (heat) energy, and more importantly, time, both to heat up and cool down. This is without considering how you're changing the internal structure of the metal by heating it up.
Finally, the torch costs $, as does the fuel to run the torch. I imagine it'd be easier to build a press that can form whatever thickness steel you want than it would to heat each sheet, otherwise we'd see larger machine shops / fab shops practice preheating before bending (we don't).
What kind of torch?
X2 ^^ agree 1000% YES 1000%... Screw the torch... I just throw another 32T jack on top of the punch die HA!
J
