Builds And so it begins...My '13 LX 570 Buildup...Help me! (1 Viewer)
Hey thanks for taking the time for such a detailed response. I’ve been toying with portals, big time. I didn’t think 74Weld made them yet for our 200 series yet. I’ve seen Jason Well’s recent install of his Werewolf portals. I’ve also read recently if and when 74Weld build them they may not do a gear reduction, which personal would prevent me from getting them. I think that would be a dumb choice on their part to not have a gear reduction to bring ratios back to stock while running 40’s. I agree on the E&E spacers and brackets front and rear and planned on that to help keep the tires out of the fenders. And, for the type of wheeling I normally do and probably will end up doing in this thing, lockers are inevitable as well. The problem then is do I go ahead and regear or not…all depends on the portal decision and what gear reductions they offer. For me, if bringing back to stock ratios typically is 4.88’s, I’d go 5.29’s or whatever the next size up is for these to gear it lower, because it’s just what I like driving wise out on the trails. I have 38” nitro ridge grapplers and going to try Maxxis rzr mt’s on this build, but don’t think they make a 38”. Ill double check that, but I have to run 18’s or 20’s to clear the Powerbrake BBK, which brakes so awesome now on this thing.
The challenge is the wheels and depending on what setup I choose to run suspension wise really dictates the dang offset and just how much trimming I’ll have to do, as you know firsthand. I’ve found a great company ML Forged wheels that will make me whatever wheel design, color, offset, beadlock or not wheel for it, but I have to land on the suspension/portal setup before that. I’d like to go as wide as possible with suspension or portals and then the highest positive offset wheel that will clear everything to keep it from being retardedly wide. But, in reality, ever Jeep in the world is really only able to accomplish their big tire builds with a ton of poke, so everything clears on lock to lock turns while compressed. But the big difference is the stock rear axles are wider to match the front already. I don’t think without going portals that I could run a tundra long travel without a regardless big steel wheel spacer or different offset wheels in the rear than the front.
All great feedback…appreciate you taking the time to thoughtfully give it. And I like hashing out ideas with the other guys on here that have already done amazing big builds.
Chris
I spent a few hours re-assembling the front and rear bumpers and all the side pieces. Everything went smoothly today. I relocated the hitch pins mount to up inside the rear bumper crossmember, so it won't get ripped off. Outside of that, I bought a bunch of clips, so I can make up some pieces to reconnect/extend the stock fender panels. Tomorrow I hope to have it back on it's own weight, and test to make sure it shifts in and out of park like normal, and the steering wheel movement feels uninhibited. Outside of those last few things, the next wrenching party will be installing the TKO angled sliders.
Chris
I got the body lift and to angled sliders installed today. I’ll have to snap some pics tomorrow. At the recommendation of someone on NST’s thread, I used some plastic sheets and filled in the gaps for the plastic panels in the front wheel wells. Got all the clips from local auto supply store.
Chris
Ordered my skids...was going to go lightweight aluminum and skin them with UHMW myself or have Factory UTV do it, but decided knowing my wheeling style I'd be making a poor decision lol. So, here's what I ordered from Bud Built. I'll probably skin the undersides of certain areas potentially with some UHMW to help it slide over some of the areas that are so prone to drag once I get the skids installed and see what I'm dealing with for mounting options, etc.
Chris
I decided that running back and forth to my parent's house to work on my vehicles was taking too much time. So, yesterday, my Halo 9K lb 4-post and 14K lb 2 post lift arrived. So of course I stayed up will 12:30am to finish the install of the 4-post lift lol. I'll be using this one to store our Turbo S and whatever else I can fit on it at the same time and park one of the cars underneath.
Nice choices!
