Amp under Drivers seat Question
Is there airflow? Can you access your knobs on the amp for gain and such?
I mounted the amp in the rear behind the panels. Mounted the amp to a couple of strips of steel I put back there and re-installed the panel. No need to replace or modify the nice panels.
I obviously didn't explain myself properly. ^^^ this is what I meant.
I was saying, if you're in there you might as well replace the particle board that the vinyl sits on. Especially if its all nasty and broken and molded like mine was. I took two projects and combined them into one. I apologize I have ADHD, and I don't always communicate effectively. :)
No we understand, Not all side panels are in your condition. I have a 1 owner California car. Side panels are like new.
Elaborate on what? You grab the panel, pull a little, and Voila! Panel off!
Have you never tried to pull one off before? :confused:
I'm partially brain dead and and couldn't fathom how to remove the side panels.
Thanks for putting me on the right path! :popcorn:
Ha! Just be careful and you should have no trouble removing and replacing them.
