Thought I would post up some pics of my latest project, a 29" x 19" x 3" aluminum crossflow radiator with Extreme BlackMagic fan to cool my SB350. I just got tired of trying to make the stock LC radiator work with unsatisfactory results... the stock LC radiator IMO was NOT designed to cool a SB350, but the straight six LC motor.
I used the stock LC bracket, cut it about 1/2" from frame height and welded some angle iron on the bottom to mount the aluminim radiator. The radiator sits approx 1/4-1/2" off of the frame, I did this to allow body flex on extreme angles. If anybody needs lower mount pictures I can try and post some. The Black Magic fan pulls 3300 CFM and only draws 18 amps. Also has a built in shroud that fits perfectly on this radiator, its a great combination. Summit claims this radiator will cool a 350-400 HP V8 with no problems.
Needless to say, drove it around town last week and she never broke 185 degrees, my old stock LC radiator would run 195-200 around town. I have already noticed a 15 degree drop in temperature! Fan is on an auto thermostat with toggle switch to over ride. I picked the radiator up for $189 from Summit and the fan was $250. Total install price with new hoses/clamps and radiator fluid was $500. This radiator has a much larger fluid capacity than the stock LC radiator.
Just an idea, I know V8 cooling has always been a hot topic. The true test will be the 105 degree day, time will tell.
