Yeah, those crimps are crap. Easiest to fix is with a hammer type crimper and some good self-adhesive heat shrink.
Amazon LINK
Amazon LINK
I’ll add that to my list of tools.Yeah, those crimps are crap. Easiest to fix is with a hammer type crimper and some good self-adhesive heat shrink.
Amazon LINK
Depends on the fridge. Per the specs, my Engel pulls 2A max, and probably less than an amp under normal use. Maybe I should actually measure that some time.There will be a question that may go unanswered once I complete this: What caused the shortage?
I have a “theory”, though.
The previous owner installed an extra fuse panel under the hood. He had told me he had it in mind to install a fridge inside of the truck.
Call me crazy or inexperienced, but from what I understand about stock 60 alternators, it’s already what, 55 amps? I don’t think it can handle the load of a small fridge? What do any of you guys think?
A surprisingly common reason for that red fusible link to fry is because a wrench hit grounding when someone was removing the alternator leads without disconnecting the battery.
Ah. That actually doesn’t sound so bad, then.Depends on the fridge. Per the specs, my Engel pulls 2A max, and probably less than an amp under normal use. Maybe I should actually measure that some time.
Great. And yeah, I gave them a little tug to make sure. Seem to be a-okay.I think those look fine - very good, in fact. If you're worried about the crimp, just give a gentle tug and if they're snug, you're good to go. You can check for continuity also, just to make sure connections are good.
