I have noticed that on my 100, that my alternator seems to do a better job when cold. 14.3 volts via the odb-II port in the morning at high idle. Once warm/hot the most I see is 13.4-13.5 volts at any rpm. If I am idling in traffic the volts drop into the low to mid 12's.
I'm pretty sure the voltage regulator in the alternator is going out. Thoughts?
I'm going to end up replacing the alternator with a mean green 200 amp model. I will upgrade the charging cable as part of that install. I'm just wondering if I need to replace the alternator sooner rather than later. Opinions?
Thanks,
Thanks,
