alternator connections for fzj80 alt on a 1HZ in a 60
Iowa
putting a 12v 1hz in a 60 - reading here pointed me toward using an alternator from an fzj80 (which bolts in perfectly) but I'm needing help with how to wire it into fj60 system
the 80 alt has the B+ stud plus a plug connector with three pins in it, while stock 60 alt has the B+ stud but only two pins in its plug connector
pic shows 80 alt plug
searching has yielded toyota connector pigtail part 90980-10841 which looks correct to fit plug, but can anyone advise which of the pins to use, and where they need to connect into the 60 electrical system?
thanks
This is the color code for the Toyota FZJ80 alternator pigtail I used for my 1HZ. Looking at the pigtail connector pins, the black wire on the left is your sense line, the middle green wire is your ignition, and the red on the right is the charge lamp.
thanks
thanks for the response - did you mean to attach a picture or something or are you referring to the pins as oriented in my pic? I don't have a fjz80 pigtail readily available
also would appreciate understanding what are the corresponding connections on OEM fj60 altternator/harness plug where there are just two vs three connections plus the B+ lug
appreciate you DB3, or anyone else that can help...
after a little more searching I believe this shows correct pin labels (as DB3 described)
assuming so can I connect IG and L to corresponding leads on fj60 harness plus then connect S to the B+ terminal along with the white/blue stock 60 harness connection? Or does the S pin need a seperate wire to the battery positive post?
thanks
Unfortunately my pigtail is not color coded, but the photo should be enough to ID the pins. The sense on top is connected to a white wire coming from the fusible link, the middle is the black/yellow ignition wire, and the bottom is connected to the yellow charge lamp line. I cannot recall where the yellow charge wire was originally connected to the 60 alternator.
thanks for the pic
As I recall, I ran a separate sense line directly to the battery, but it’s been too long ago. I hardly remember what I did yesterday...
