So on my way home from work the otherday i noticed that my volts were really low just above 8 or yellow so I assumed alternator is going but the next day i started up my 60 and my volts were higher like around 10 or 11 , i put it in reverse and my volt dropped back down assume its back up lights because same thing happens when I turn on my headlights but if I turn them off volts jump right back up but not where they should be i.e. 12v its weird if i turn on my turn signal the volt meter jumps up and down in time with the flasher. I am ready to pull the alternator and have it tested.
