20.5 was the magic number for the torsion bars, got an alignment and everything is great! It drives straight and very true now. thanks for the help spressomon!
pfran42 said:I measured my center-hub to fenders and got 21 7/8. I am running OME 863s in the back as I have skid plate, roof rack, drawer plans, but as it sits today, lowering the front to 20.5" is going to look a bit odd.
4Peanut said:Perusing some oldish threads...
Paul, is 21 7/8" your front measurement? What's your front setup again.
Thanks for the update Dan! Looks like I am going to just go with the tried and true 10mm spacer and see if it gives me the extra room I need around the reservoir.
Sonk, I'm curious: What's your goal with 1.25" wheel spacer adapters? Visual thing? I would think the scrub radius effect (and wider turning radius) wouldn't be conducive for the tight/twisty/wooded trails you have back there.
FWIW: 10mm wheel spacer up front + 1" BL + GY MT/R 285-75R18 = no rub on fenders. Also running two soft Timbren bump stops per front lower control arm for very nice bottom out control.
With the 12mm/.5" BL, 10mm wheel spacer and same tire as above I was, on big front suspension bottom out, getting a little tire to fender liner interference. That was the reason I went to 1" BL which has eliminated the interference. And no rear of front tire interference...and I'm running about 3.75 degrees of caster.
Did you fold down the body seam on the back side of the front fender well?
Any updates on your experience with the 10mm spacers? I just installed 1.25" hub centric ones in front and rear. And right away, I could see number of the same challenges you were having with rubbing at top/back of front wheel well. (I'm running 12mm body lift, so I thought I might be ok.)
The back is great with the 1.25". I'm now debating between 10mm for the front and/or 1" body-lift... or just living with it. I'm running 285/75R18, so not exactly the same time.
..... Unless someone comes out with a better design (SpressoFab).
