TC UCA Alignment questions and binding noise help
Since upgrading my suspension over the past few months I have had nothing but trouble getting everything dialed in. On the front my truck had the TC UCA's, Radflo 2.5" remote res shocks, Timbren bump stops, 1 1/4" spacers, 295/75R/16's. I have rebooted both lower ball joints, replaced both outer tie rods, replaced steering rack bushing, and new sway bar links and bushings, and repacked the front wheel bearings.
I just went in for my 3rd alignment in since November. My wheel is still rubbing at the back of the wheel well when turning in the spot you normally have to trim to run 35's. (again I am running 295's/75/16) I have run the same tire for a few years now and have never had this issue before. I am guessing the TC UCA's pull the tire back further towards the back of the wheel well. If I adjust for more positive caster, will that bring tire further forward in the wheel well? or is that not really how caster adjustment works? They are currently not getting caster within specs which is supposed to be one of the benefits of the TC UCA's. The right is currently set at 0.7 degrees and the left is at 1.4 degrees. If that was changed to say 3 degrees of caster which is within spec, would that bring the wheel further forward in the wheel well? I have been reading and reading everything I can on alignment, but still do not understand this part. If in the end I have to resort to a BL and trimming this part to fix the rub I will. But, if it is something that can be corrected through alignment, I would prefer that first as long as it doesn't have other negative affects. I am trying to make sure I understand everything before I go back up to complain about the alignment.
Next problem I need help trouble shooting. When I put the car into reverse and back up turning to the passenger side, I get what I would describe as a bid and popping sound. With SO much being new and/or rebuilt there, what should I be looking at as the cause? CV? Lower ball joint? Steering tie rods binding? Again it is all new since all the work and alignments.
Thanks! Starting to wish I just had my old Slee OME medium lift back on....
