Aisin Manual Hub's
Bryant, Alabama
Gentleman and Ladies,
Ya'll know of a rebuild kit for these hubs.
Or has anyone rebuilt them and have a parts list or supplier.
Im preparing to do a Front Axel rebuild. Mine may or may not need it but I'de like to be prepared with whatever if they do.
Thanks all.
If the front of the hub is not leaking then there is no reason to rebuild them. Besides, a rebuild consists of a new rubber seal...
I've rebuilt a few and pulled apart a few... only seal I could see needing replaced is the rubber one mace is talking about on the dial. I usually put a light coat of grease on it. They have all been dry on one edge but have never ripped when I pulled them to sand blast. There are a few clearance washers on the ring but I've never replaced them
http://www.pirate4x4.com/forum/showthread.php?t=281879
Don't mean to hi-jack but does the kit still work if you have warn hubs?
Hubs
Thanks Ya'll
For the responses and great info.
the seals do.. But I would assume that the rubber o ring won't
Be carefull with the spring .. !!!!! I disarm mine to put a new grease and :D hahahaha can assemble it again .. :eek: so I need to call a friend ( mechanic ) to put it again .. :frown:
