I think this is a very clever system. A mechanical solution right before computers took over fuel/air delivery. It simply adds more air to the idle,primary, and secondary circuits while advancing timing at altitude.
You got it. The 3 ports for air are going to open by themselves. I just didn't want the vacuum leak since I'm at about 130' most of the time.@mwebfj60
So the way you've set up the HAC with the vac switch hooked up to the gas filter, is to allow for advancing distributor timing at altitude ?
When I desmogged, I decided the designed vacuum leak needed to be fixed. My solution was to use the two port Nippon Denso vacuum switch and control the vacuum off the gas filter with it and a switch in the dash. When I head to altitude, I flip the switch at around 3,000ft and the HAC functions as normal. When I head down, I turn the switch back off.
