Air Conditioning help needed
Odessa Tx
I pulled the AC compressor and drained it of oil. replaced the drier and expansion valve but the retrofit kit to attach to the schrader valves I bought doesnt fit on my low side. Can anyone help me with a link or part number to get the right retrofit kit?
The low-side adapter is Four Seasons #59976. The high-side port can be either 1/4"flare, part #59977 same size as the low-side or it can be smaller 3/16 flare, part #59978. Low-side fittings are always 1/4 flare. Check to make sure you're not screwing the low-side fitting onto the high-side port.
1976711
1976712
1976713
View attachment 1976711View attachment 1976712View attachment 1976713
the low side fitting is smaller diameter and longer already had a Schrader valve installed in it. it was too large for the fitting on the compressor. I am going to look for a local dealer of Four Seasons stuff and see if I can find the parts you listed. Thanks for the help.
Ok another question the hoses I have for my manifold look like they will screw directly on to the Schrader valves is it a bad idea to do that?
