I've spent the last few hours searching with no luck. I really hope someone here can help.
My LX470 refuses to go into H or L. It is stuck in N and will only flash twice when you push H or L and not do anything. Its the same as when the doors are open and you to adjust it or if you're going to fast and try to go up or down. The off light does not come on at all unless you push the off button.
Ive hooked it up to techstream and all my sensor are reading the proper height and are changing when put my weight on the sensors side of the vehicle.
I jumped the pump to see if maybe it was dead, and it still works.
It worked completely normally yesterday. The only thing I can thing of is I recently installed the Slee override and it was working perfectly. I taped it up and mounted it between the metal and plastic kick panels below the steering wheel since I didn't have factory button space, the wires were not long enough, and I didn't anticipate needing to switch it on/off.
Anyway, after the AHC quit working today, I reached up between the panels and noticed that it had shifted. I wonder if maybe one of the prongs on the board got exposed and shorted on the metal kick panel.
If it did, it must have messed up the AHC controller module and made the vehicle think its going to fast to change height.
Someone please help! I wonder how hard it is to get ahold of AHC controller module since so many people go to a standard suspension.
