I have changed accumulators, changed AHC fluid again and ... there is no big difference in ride quality
Car is a little bit softer on big bumps but if tarmac become rough I can feel everything. Whan I am changing the height setting from ‘low’ to ‘high’, the oil level in the AHC reservoir is 13 graduations instead 8 graduations before. I would like to go to Toyota and ask them to check pressure of shock absorbers, adjust sensors and check their wirings. I need also to try another car with good suspension to drive and compare to mine.
Ps. If someone want to change accumulators use Fan Spanner 32/36mm. No need of grinding. If it will be difficult to unscrew hit accumulators firmly few times.
Car is a little bit softer on big bumps but if tarmac become rough I can feel everything. Whan I am changing the height setting from ‘low’ to ‘high’, the oil level in the AHC reservoir is 13 graduations instead 8 graduations before. I would like to go to Toyota and ask them to check pressure of shock absorbers, adjust sensors and check their wirings. I need also to try another car with good suspension to drive and compare to mine.Ps. If someone want to change accumulators use Fan Spanner 32/36mm. No need of grinding. If it will be difficult to unscrew hit accumulators firmly few times.
