48997-60010 closest to height control valve
48998-60010 middle, most likely to fail
48999-60010 closest to pump
They're like brake lines so someone can fabricate them
Ok so I poured about half of a plastic cup of fluid into a funnel that was plugged into the reservoir... half of it made it to the floor which was frustrating. Then I rechecked the thread.If you haven’t done it yet illuminate the reservoir from the other side with a bright light. It is very difficult to see the true level once everything is that dirty.
It works better to put the light behind the reservoir.Ok so I poured about half of a plastic cup of fluid into a funnel that was plugged into the reservoir... half of it made it to the floor which was frustrating. Then I rechecked the thread.
To your point.... I'm having a hell of a time trying to figure out the actual level in this reservoir. Kind of impressive how hard it is to check and I'm using what i thought was a pretty bright light.
After 30mins of moving a light around I think the level is actually ok.....View attachment 3360728
This. I should have said back light the reservoir.
