What’s the status of “main relay expectation” ? I’ve never seen (or more to the point noticed) it OFF before and I can’t help but think there maybe a relationship between it showing OFF and the 0.7in difference in front height sensor readings during your non test mode drive. The +.2/-.2 readings are good/ok for stationary readings. I’d try and get both of them closer to zero and then see what they are during a normal drive and if main relay expectation is ON when there’s less of a sensor value spread (and hopefully the dampening is good). If the front height is creeping up due to worn sensors or electrically noisy sensors (think a scratchy volume control on an old amp or stereo) then the increase in pressure degrades damping ~ 1in in height equates to 2.2MPa in front pressure. I’ve long thought that height sensor dynamic feedback could be the root of many undiagnosed AVS dampening issues. After all it and speed are the two critical inputs to the ECU for adaptive variable suspension.This pic was taken on level ground with truck running in N. View attachment 1918412
Sounds about right, that display isn’t degrees as generally understood, ie in 360 degrees in a circle, but a mystical electronic representation. If you do a lock to lock turn turn (about 3.4 full turns of the steering wheel) you’ll see that value change from +1100 to -1100s - or something similar. I don’t believe your problem lies with steering angle, I’m more interested in why your damper switch 1 data field is now blank and previously you had a blank main relay expectation field. I’ve never seen blank fields, seen offs and ons, strange numbers but not blanks. So now I’m thinking either the AHC ECU data is valid and the mVCI has random issues - the data protocol is old, simple, single line stuff similar to Rs-232- or the ECU or its interface is behaving randomly and the mVCI is reporting what it sees, albeit inaccurate incomplete data. It wouldn’t hurt to pull and reseat the 3 AHC ECU connectors, check and clean the signal grounds and operate your laptop off battery or mains (not a vehicle powered inverter) to ensure there is no floating signal to ground shenanigans going on.Sorry I really screwed that up. Turning the left a 1/4 turn yields -103 degrees and a 1/4 turn to the right yields +79 degrees.
You got it to raise from L to N with the sensors disconnected? Haven’t tried that one beforeThey dropped by .6 I should have mentioned that.
Pressures aren’t constantly monitored, they are just snap shots of the pump output at the time the respective solenoid switches so you can’t put any stock in them other then what’s reported during a L to N raise cycle. And even then it’s very easy to get spurious readings. Yes, the gauge just replaces a bleed screw, you do your L to N lift and read off actual system pressure with no guess work or second thoughts. After adjustments you then depressurize, remove the gauge and refit the bleeder. You could easily rig up a permanent arrangement too.I was already in N when I disconnected the sensors and it stayed in N. Have you ever seen a bad pressure sensor? I’ve gotten a lot of pressure readings in the 2’s and 3’s mostly in the front but occasionally in the rear. Even after cycling from H to L then back to N I’ll still get some goofy readings. When checking the pressure with a gauge do you just hook up the tubing/gauge to the bleeder screw?
Paddo, I finally found the problem it was a bad AHC ECU. I ordered a used one off ebay for $90 and installed it last night. The crazy thing is I never had a trouble code for anything. My rig drives nice and smooth now. I'm going to recheck my pressures again later today and finally start enjoying the truck again. Thank you so much for all your help.
