Attempted to do the Paddo AHC bleed procedure today. The bleed screw on the Height Accumulator was so tight the outer part of the bleed screw sheared off. Most of the threaded part of the bleed screw remains in the threaded hole. The threads are probably galled or nearly fused together.
I went ahead and bled the system from the 4 bleed points near the globes. None of those bleed screws were stuck. So at least I got some fresh fluid in there, even though the height accumulator did not get bled and that was the first in the order of Paddo's procedure.
What to do now? Hopefully I can drive like this for a while. I have experince with threaded fasteners and there is no easy way to get the rest of that bleed screw out. It seems to me the entire accumulator would have to be removed from the frame in order to successfully remove the broken part (plus any metal chips created by the removal process). That seems like something that would have to be done by someone experinced with servicing the AHC system. And it would likely mean all the fluid would drain out. Am I wrong about that?
Thanks!
Thanks!
