Ahc Front in Air, rear low and not responding to anything
ireland
Hi Folks I got some cvs don’t on my truck to stop the power down clunk, on the way home noticed front end was a bit high after stopping and then parked it. Drove it 3 days later and the front end up in the sky and rear a little low. I’m sure it was on a lift I can’t get to under neath it to disconnect rear sensor. I can see the garage that fixed the cvs disconnected the battery of the vehicle if that has anything to do with it. Suspension will not lift or drop, no error on dash, rear is about 860mm from ground to 910 on front. I can see they didn’t touch the front sensor but I wonder did they move the rear. Anyway, if I disconnect the rear sensor should that level the truck ? It will not respond to any of the height adjustments at all either. All help is appreciated
