AHC Flush failure (2 Viewers)
Yes we got it going, it's been working well for 2 days.
I removed the AHC pump motor assy. removed pump off the motor, and disassembled the pump removed rubber o-rings and sprayed and cleaned in carburetor cleaner.
Didn't see anything clogged.
Soaked pump in AHC fluid and rotated, left in AHC fluid overnight.
Tested pump and primed, plugged outlet hole and replaced assy. back.
Started LX and everything started working.
Relieved to hear! And you did that with lightning speed. A bit confounded as to what made it work in the end?
For others, found some information that may help
I thought I would add to one of these many ahc threads, mainly because I have read all the threads, even those 43 pages deep to see who if any have had similar issues and have been able to resolve them.
I have a 2013 lx, replaced ahc fluid at 180k km, then globes and pump at 220k km (w new fluid), and now replaced my shocks (accumulators) as the rock guards were rusted and eaten away but otherwise didn’t leak. Yes I know, don’t fix what ain’t broken but I don’t like when things are wearing externally. Although it was tough getting the parts off and replaced with the new parts, it was relatively drama free. I tried to fill the shocks w new ahc fluid (yes metal cans) before tightening it all up but who knows how much I got in there. I had a hard time getting it to raise at first, cycling the car on and off. I have techstream and used to erase the code which was abnormal pump pressure c1763. I eventually got pressure to build by cycling the pump on and off using a direct 12v battery to the power outlet on the pump. I would unplug it in the back and apply 12 volt for a couple seconds then the pump would grab and pull fluid. I would do this over and over to build pressure from about 2 psi to eventually between 8 and 11. What is weird is even after erasing the fault code via tech steam, the pump would restart and run without necessarily building much pressure. the pump would still be on and pumping then all of a sudden stop with the error code c1793. I would unplug the power to the pump, apply 12 volt for a couple seconds and plug it in, erase code and it would build pressure again. I estimate about 4 or 5 of these cycles and the pressure would be high enough the pump would naturally stop when the height was where it should be. I did a number of fluid flushes once at height - I estimate I put through about 5 liters. I only did the four bleed corners, not the 5th accumulator. The car drives poorly even though the code isn’t thrown. Eventually it gets thrown after a few minutes of driving. I can drop the suspension with the switch, but when I try to go back up the back raises briefly and then the pump spins and cuts out w the c1793 code. I have about 35 hours into this whole job and now on the finally stretch I can’t figure out what’s going on. I suspect maybe there is still air trapped, but I did so many bleeds. There is some discrepancy in how the bleeds get down ie one corner at a time and restart, do all four and then restart. Only bleed until air is done coming out, or bleed until in bump stops etc. I tried all variations. Same result. The only thing I haven’t tried is bleeding that 5th. Or any other thoughts from the gurus out there?
Are you absolutely CERTAIN you have enough fluid in the reservoir? Check very carefully because the reservoir becomes stained with the fluid dye and it’s very difficult to see the true fluid level.
Yes, of course. When I manually bump the pump repeatedly during a normal lift attempt cycle it eventually goes. I personally replaced the pump and reservoir last year, so there is no staining on it. It has slightly above max .
I was thinking three courses of action, but they are contrary to the fsm testing procedures for c1793 and rely on common sense. Now, I am probably wrong but I am thinking of simplicity first. The system worked perfectly before I took out the suspension and replaced it with new. I think two things- one, it may have air in it still. Even after cycling 5 liters+. I think I will use Anymals procedure and raise the back end on ramps and do some more cycles manually thru bumping the cruiser direct thru the power source. Two- I can do another flush cycle, this time one corner at a time and allow it to charge again, albeit manually I will have bump the pump likley. Three I can take the pump off and see if there is an obstruction in the reservoir. The reason I think this may be a factor is when I am applying power direct via 12 volt to the pump, I am actually reversing polarity and pulling fluid back as my 12 volt is on black in the connector and the ground is on the red. I think it is reversing and priming using fluid ahead of the reservoir and pushing some fluid back into the reservoir, perhaps pushing an obstruction back into the pool of fluid. I think it may then work its way back to the inlet that the pump is pulling into and trying to prime in the normal direction and perhaps not getting the pressure built due to this? Someone please provide me some ideas or rationale of what I should be doing to overcome this. It’s driving me nuts and the whole system is basically new.
I think you have answered your own question Seems like some debris was introduced during change of components. You had rusty suspension components. You can take out the pump out and clean it. Or new pump.
I am not ruling anything out, and I think I will get to looking inside the pump, however, it’s a closed system and because rust is on the outside doesn’t mean it gets inside. More realistically debris could be introduced when filling, as even though I cleaned the area around I did remove the filler filter as it’s painfully slow when filling. There is a code for obstruction- I don’t know if that’s a line only obstruction or if that could be also thrown reservoir side as well on the suction inlet going into the pump to the hose circuits. I took my old one apart and cleaned the filters when I was trying to salvage the first and realized although it still worked the motor was far from deaths door step. I appreciate the external view and encourage additional perspectives of those have been down this road before also. Thanks for taking the time to respond.
Okay so an update after another 8 hours on this thing. I took the pump apart three times as each time I had a no turning of the pump, until the last time when I clocked the gears and aligned the slot on the gear cylinder notch properly. There are minute nuances to the reassembly that matter that I found in other threads. I also cleaned the screen inlets and had stuff in there that likley added to the cavitation and inability to maintain prime. I bench tested and it moved fluid well and I buttoned it up. After reassembling it all and priming on the truck I tried to have the truck lift and a c1763 code came on again. In techstream I could see the same fault and erased it, but upon clearing it, it would trigger immediately. I am telling you I was about fed up. I went back to basics and started from the front - test relay, power to relay etc. all be darned I also blew a fuse manually jumping the pump because the 50 amp fuse was blown. Relay wouldn’t work as a result and I simply pulled over the rear ac fuse to the ahc and started the truck. Immediate lift. Everything worked perfectly up down and side to side. Thank goodness as I have about 60 hours into the starting from replacing suspension accumulators and flushing. I don’t think I had any more patience in me but simplicity sometimes is what trips us up. Thanks for being a sounding board and for those who have contributed to previous threads that helped
So if I understand it could have been some debris and also you had a bad fuse?
The primary was debris - the secondary was blowing a fuse after manually jumping the pump. I am not sure to what condition changed as before I was constantly bumping it to build pressure but the only way it worked was reversing polarity (although it proved to be blockage preventing holding pressure). after I rebuilt the pump a few times and cleaned it the only way the pump worked was with regular 12v applied to the +ve side, which was the proper way.
All the above being said the material in the filters did not look like dirt, but was some pink (fluid coloured) material. All the ahc supply I used was always from the metal tin.
