Maybe I'm the only one who's been struggling with this, but I decided to scrap the whole oem wiper assembly after numerous attempts to fix it. Typical problems included, wiper links falling off the pivot arms under the dash, wipers failing to stop in the park position, stripped wiper arms , and worrisome sight of watching the sheet metal, where the wiper motor bracket mounts, undulate up and down with every revolution of the wiper motor. I figured it was only a matter of time before the metal was going to fatigue and crack.
So this is what I came up with:
Specialty Power Windows WWK-2 Standard Universal Wiper Drive Kit
It's a little pricey, but what isn't when it comes to the well being of these pigs.
I have some install pics to follow, but I'll preface by saying don't do some of the things that I did.
You will have to remove the instrument cluster, switch panel, and glove box to do this install. After that, disassemble the wiper links and remove the pivot assembly, but leave the mounting bracket for that assembly. Here's a pic:
The new wiper assembly comes with a geared pivot arm that is driven by a cable that slides back and forth. I installed the new bracket right over the old one. It bolts from the outside using a spacer and a nut.
Next is cutting and bending the aluminum tubing that creates a chase for the cable to ride through.
