Affordable skid plate
Anyone make a front skid plate with an oil filter access like the 100 series? Looking for affordable solution don't need it for off roading. Thanks
I would highly recommend the E&E skid system by @turbo8 . It's not the cheapest, but you definitely get what you pay for in craftsmanship and detail.
Save the skid money and get a 3/8” cordless impact. Just under a minute to remove all 3 necessary parts.
If you use it to reinstall take it very very easy and final torque by hand.
I just got done putting riv nuts in as many of the holes were stripped. I'll be taking it easy from now on
Just putting this out there, but an investment in bigger 33" tires and a mild sensor lift may negate the need for skids at all. At least until rock crawling at a level that demands it again.
Step 1: Remove OEM skid, mark approx location of oil filter.
Step 2: Borrow a 4" hole saw from your plumber friend, drill a hole in the skid. Clean up hole with a file and emery paper, spray with some satin black paint.
Step 3: Reinstall, return hole saw to friend with a cold beverage as payment.
Thoughts on allowing mud/water/road debris a direct path to splash onto the lower serpentine belt?
