(also posted on DTLC)
So I purchased to rubber cased driving lights and swapped out the 12V 55W bulbs with 24V 100W bulbs. I also purchased a switch and a Bosch 24V relay that will handle up to 30amps.
Of course I am stuck on the wiring. Here is what I have (and where I am at).
__________
| 87 85 |
| 87B |
| 86 30 |
The fellow at the shop informed me the following:
87 - Light
87B - Light
86 - Ground
85 - Switch
30 - Battery
So here are my questions:
1- I am assuming that I connect (30) to the positive post on the the drivers side battery, that is were all the other wires go
2- Does it matter which post on the switch (there are 2) I attached wire to (85)?
3- Can I ground it by bolting to the metal dash?
4- I have an inverter (IPC 20 I think) in the glove box, rather than run a wire back out to the battery, can I run a wire to the 24V input on the inverter seeing as it has a wire running from the Battery already. Or would this cause trouble.
3- The guy at the store told me that the other post on the switch needs to be connect to the battery as well. This seems odd to me and is what I worry about. He also said it could be attached to the ignition switch - where would I locate that?
What are your tips on this? I am sorry for the rookie questions, I really am learning - just not too quickly!
__________
| 87 85 |
| 87B |
| 86 30 |
87 - Light
87B - Light
86 - Ground
85 - Switch
30 - Battery
