I’m seeing a lot of different options out there for OBD2 readers now and was thinking of getting one. What setups are y’all using and what do you like/dislike about them?
I literally use the same set up. Works greatI use this plug-in scanner from Amazon - wifi not bluetooth
Amazon product ASIN B077F8F6TB
In combination with 'car scanner' from the App Store (IOS)
I sometimes pull a camper with the hundy and was concerned about the engine temperature when towing - this enables the engine temperature to be monitored when the camper is hitched up. Temp gauge on the car did not move, however the car scanner data gives more definition and confirmed the correctness of the vehicles gauge.
This set-up provided all I need for small money..... seems to work good - no negatives.
For your consideration - with hindsight I'd really have preferred an arrangement that also gave transmission temp too..... there are ways to do it and plenty of threads - here's one - OBD 2 just received now.... - https://forum.ih8mud.com/threads/obd-2-just-received-now.1066799/I’m looking for the same information as OP and curious if anyone else wanted to share additional “best” options?
OK - you prompted me to action as I am towing the camper to Moab this weekend - I just purchased OBD Fusion + the Toyota add-on ($20 total) - can now see the 'AT fluid temp' - takes 10 mins to install - can get a dashboard on iPhone (IOS) - works with my existing 'Foseal' plug-in wifi OBD scanner (see above) - might even put it on the IPAD - easier on the eye.I’m looking for the same information as OP and curious if anyone else wanted to share additional “best” options?
I am updating this thread for the sake of others who may be interested. I went with the OBDLink MX+ Bluetooth scanner which comes with access to its own “OBDLink” software, and can also easily be used with Carista among many additional software options.
What app are running, I have tried a lot and no go, they all connect to the elm327 mini bluetooth but they will not connect to the ECU. hmmmmI use this plug-in scanner from Amazon - wifi not bluetooth
and do you run app on a smart phone if so which appI have this one. Connects quick and reliably and I can get trans temp through Torque: https://amzn.to/3Ii17pc
Torqueand do you run app on a smart phone if so which app
OBD fusion + Toyota add on ($20 total) - use iPhone and iPad - gives Transmission temp - useful when towingWhat app are running, I have tried a lot and no go, they all connect to the elm327 mini bluetooth but they will not connect to the ECU. hmmmm
Yes I have done that paid for the pro version and got the toyota 2000 add on for $20 new zealand but still no go connecting to the ecu, my phone connects to the bluetooth elm327 fine but the app can't connect to the ecu I have a 2000 landcruiser VX 1hd-fte 4.2 diesel 4 speed autoNew Zealand build, very disapointing!!OBD fusion + Toyota add on ($20 total) - use iPhone and iPad - gives Transmission temp - useful when towing
sorry to hear about ur situation - super frustrating I can imagine - For reference I have 2000 LC 4.7 petrol (USA spec) - I dont know specifics of ECU connectivity - I just did what someone else recommended...Yes I have done that paid for the pro version and got the toyota 2000 add on for $20 new zealand but still no go connecting to the ecu, my phone connects to the bluetooth elm327 fine but the app can't connect to the ecu I have a 2000 landcruiser VX 1hd-fte 4.2 diesel 4 speed autoNew Zealand build, very disapointing!!
