Adjusting 200 series headlights
Mobile Alabama
I had a small front end accident which required replacement of both headlights. The beams are low and need to be raised.I cannot find the adjustment screws. Can anyone assist with their experience? Thanks
depends on what year
my 08 is horrendously difficult to do driver side. You need fingers of a 4 year old to turn the screws since battery is in the way
passenger side is super easy - turns take forver for the change as turn of screw hardly makes a difference
Yes, depends on year. Use this search term in google and you’ll get several threads:
200 Land Cruiser headlight adjustment ih8mud
2021 LC
Are you still looking for guidance? I can grab some pictures from my '21 later today and show you where the adjustment screws are. There are two slots on either side. One controls up and down, one controls left to right, for a total of four screw slots.
The up and down slots are on the far outer edge a bit higher up than the left to right slot.
At least on my '21 with LED lows and highs, where I'm pointing to in each picture is where you'll find the screw for up/down.
There is a diagram near each that shows which way to turn, be sure you use the diagram that applies to your situation. In my case, it's LED hi/low, so I use the bottom left quadrant diagram.
