It won't affect the ride quality as you're not changing the spring rate, only the neutral point. However, the heavier load will cause greater defection for a given bump. For example, if you normally get 1" of travel over a speed bump you may now get 1-1/4".
In theory no alignment is needed since you're not changing the neutral position of the front suspension, however the bushings are all rubber and as you increase load they could deflect. And alignment is measured in fractions of degrees. Around here, alignment is only $56, so it's a cheap solution to the question.
