MoGas what exactly are you trying to figure out ?
let us know how the oil pressure gauge calibrates against the stock gauge. that would be interesting to know.
What the offset would be by reading the engine temp at the boss versus where the factory sender is.
BTW,
I decided to check the accuracy of a gauge that I just got.
Auto gage # 2313 by Auto Meter 2 1/16" 100-280F mechanical gauge.
Test equipment is a Hart Scientific model 9122 dry well.
The results were less than desired:
Test equipment setting/Gauge indication
65.5C (150F)/ 150F
82.2C (180F)/ 180F
93.3C (200F)/ 198F
110.0C(230F)/ 225F
121.1C(250F)/ 245F
At work this would fail. We would calibrate to +/- 2.8 F (.01% of full scale) on something of this range. I could have lived with it being off at the low end and more accurate between 200-230, but not with it off by 5* in the middle of the scale.
I guess I'll take this one back and spring for the Auto Meter Sport Comp and try again.
Dave
I could do it, but the factory indicator isn't graduated in psi. I could just put different pressures in the ModCal and take pics of where the needle goes. would that work for you? Id rather do it that way instead of comparing it to a gauge that is an average 1.4psi low.
Dave
5 degrees is more than I would like but this is about what you can expect from a consumer type product,
one other thing is how tight was the metal to metal contact between the insert and sender?
if there was any air gap heat loss through the top of the sender and thermal resistance of the air could keep the sender at a lower temp than the tester, more than would be were it immersed in good thermally conductive coolant.
someone, maybe Lxtreme? has both an aux gauge and the mod, IIRC he stated they follow each other.
makes sense that they would they read water temperature a few inches apart, the stock gauge reads right before the water leaves the head, AM gauge right after it leaves the head.
I could see there being a slight variation during warm up as the water outlet (where an AM gauge picks up at) does not have much flow until the thermostat opens, but as far as I know no one has reported such.
Wow, missed this thread for a while. Not sure if LX stated this but I did, I have a very accurate Greddy Gauge and it is within zero to one degrees difference from stock temp sensor as read through the auto enginuity software (in other words not eyeballing the stock gauge but reading the raw data from the stock sensor). The two are exactly aligned ... with the exception of warmup like RT wrote and the reason for this is whatever conduction of heat within the head causes the stock temp sensor to read temps while at the same time the after market one (located right after the aluminum neck tube off of the head) wont read temps until the thermostat opens and allows flow. It is really a pretty cool phenomenon really; you can start the rig, see the stock gauge go up slowly and then all of asudden the aftermarket gauge responds with the tstat opens and allows flow. Anyways, HTH.![]()
Another question: when splicing the instrument lamp to the lighting circuit, do I splice the green wire or the white with green runner?
Dave
And your sender is tapped into the boss?
My light is grounded independant of the instrument.
So black from light to white/green stripe and red to green should make the light operational and dimmed along with the rest of the lights?
Dave
R2, Desire yes, but have not put much thought towards it except the removed zener might be possibly be used as a trigger, problem is the source is pure analog and a light and/or buzzer is an on/off thing, need to bridge that gap without messing with gauge readings (IE drawing much current from the gauge circuit, witch means needs sense and amplification) . Probably could be done with only a few components but need to put some effort towards it. Time is short right now.
If you are trying to wait for a light and or buzzer you probably would be better off to do this mod for now and possibly adding to it later, the light and or buzzer (basically a power out to power whatever alarm you want) should be an add on no effecting the base mod.
Rick that defiantly covers instructions for the mod but is not very electrard friendly.
