Did anybody try to disable ABS in winter time?I hate when the pedal gets spongy and you don't have control over the vehicle.
SamoL said:It will be harder to turn off 4WD then ABS (as this car has full time 4WD)
Regards
Samo
P.S.: LC100 is a bit expensive for learning how to brake without ABS. So I said in that thread: only for drivers who know how to brake without ABS....
bwbski26 said:all 100s in the us are full time four wheel drive. the button you are refering to is to lock the center differential. which makes both the front and rear axles get the same power.
SamoL said:some have part time 4WD.
