ABS Sensor Granaded! (1 Viewer)
mmw68
CruiserCrap.com - pimping crap for your cruiser!
Supporting Vendor
Austin, Texas
Website
store.cruisercrap.com
My first 80's tech post? :)
ABS light has been on, so I finally got around to pulling the codes (code 31).
I was hoping to just find a dirty sensor...but no!
Question #1
Are the front and rear sensors the same? Could I use a used rear sensor up front?
Question #2
Do all FJ80 and FZJ80 use the same sensors?
Here is a crappy picture..
Question #1
Question #2
Q#1- Doubt it...
Q#2- FJ80's didn't have ABS and I believe the ABS sensor is sub-series specific. ie 93-94 and 95+ are different.
That's what I thought, but still learning my way around the 80!
So...who has a Front PS sensor to sell me?? :) :)
This will be a job for Dan. I think you need the whole front harness and 2 sensors, since I seem to remember it's one piece.
Did you do a birf service without pulling the ABS sensor first? That's usually how they get broken like that. Good luck, but you are going to spend a few $$.
NTTIAWWT but you might want to also read the recent thread about unhooking your ABS. If you are going to replace- go with CDan.
Then find out what's flying around in the knuckle that broke that sensor.
-Spike
ditto to what spike said. if there is physical damage to the sensor as it appears in that thing you call a photo then that ain't natural. if that is just crud, try wiping it all off and reinstalling. a dirty sensor will throw a code.
did the abs light go on after a nasty offroad session where you really jarred that wheel?
ouch, i figured that was just part of the gold package ;)
jim it's been a while since I've seen an abs sensor but if you are correct then I will bet his spindle bushing has some "issues" and I agree that an immediate tear down is in order.
I notice Mark logged off...he's probably gone to puke his guts up (he just bought this rig 3 weeks ago.) I am due to drive over to Austin to help him replace his PHH this Thursday, schedule permitting, but I think this just took priority. I think you are right about the spindle issue...something is letting that ABS ring fling, no pun intended.:confused:
Correct.
Likely a whole bunch more when the knuckle gets opened up.
Antonio or Tom. They primarily do whsl collision stuff but are able to wade through odd-ball mechanical stuff on 20-year-old low production vehicles if they have to. They would prefer to pitch those calls to me but if I am not there they will field them. They know more about Corollas than I do and that is OK with me....;)
I'm thinking he will need new spindles, a full knuckle rebuild and the ABS parts. That sounds like $800 to me. That's a lot of Cruisercrap sales. I'll buy another bottle opener to help him out. What about the rest of you???
edit-One stainless bottle opener on the way.:beer:
Parts for a birf job, two spindles and the ABS harness would be north of a thousand bucks.
i assume a wrecker's yard will sell him a single abs sensor since it looks like it unplugs. that's probably a pretty safe wrecker's part to buy if that part of the truck is unmolested. What years could he use?
the spindle will suck and a used one is not a great solution, but I would not be so sure the other one is bad and at least he will get those nice needle bearings.
Does the factory sensor have a grey disconnect like that on top? I don't remember a provison for disconnecting it from the harness though it may be a year to year diffo and I'm not sure which of my 80s I'm thinking of.
Also, a better focus on the tip would be good. Either a wierd gleam or something's amiss.
Either way, it's pretty clear from the type and location of the grease that his head gasket's toast as well....
DougM
