Thanks guys.. I have put alot of time and money into this 4runner they are getting hard to find in this shape. I have of 13k in it and countless hours of work. If you think the price is to much just pass on by the ad. I won't take 8k for it...so save your time and mine. I have service records for it since 1985, motor was rebuilt by Toyota at 150kish, ive done new: tps sensor, plugs, wires, distributor cap, o2 sensor, oil pan, fresh oils in everything, air cleaner, throttle cable, cleaned throttle body, valve lashed, new valve cover seal, 3 inch lift, differential breathers raised, arb on board air and 1 gallon tank, new method racing wheels, new tires, new arb front winch bumper, 9k warn winch, drove to Colorado picked up the rear bumper and welded in new cross member and mounted it, has 2 jerry can holder and spare tire swing out, bottom custom top swing out is cbi, 12v power to cargo area for fridge, w56 trans, lots more.. ill take 1k off and keep wheels and tires. 3rd owner, i have a ifs box for install, new fj80 linkage, no lockers, 4:10 gears, w56 trans, 22re, method wheels, standard t case, a little rust in rear fender flares only... this isnt meant to be a crawler just a tasteful daily which it is. New HID head lights and i have an 86 rear axle as well not installed... just thinks off top of my head.. Not my first rodeo on selling things on the potential for losing money, I use to build harleys as well same issue there lol... its just out here if someone is looking im not in need of moving it asap... I'll just keep it if I'm sank in it lol.. Thanks again guys, Lee
