a442 control module signals diesel swap. (6 Viewers)
delaware ohio
Website
www.facebook.com
attempting to use a 1993 gas auto trans module in a diesel swap I've been searching for a module from a diesel truck but no luck so far.
So far I've got the TPS signal (va) circuit working using a voltage converter to send 5v to the TPS. there are several other circuits that are disconnected because the gas ECU is gone. the truck drives and shifts perfectly for about 10min. Then the OD light starts flashing and shifts at very high RPM. Code is 86 (if i remember right) "engine rpm signal" this relates to the NEO circuit. manual states that the neo circuit is a 5v pulse signal that's needed for the idle speed... the injection pump inductive sensor only puts out 0.5v as checked with a scope, it does not satisfy the auto module as expected. does anybody happen to have more information on what this signal is? i'm surprised that it says its "idle rpm" and not just rpm.
dakota digital converter does not work unless I modify my alternator i don't know if its going to output the signal the tcu wants.
Compushift, other standalone is available but expensive, They make you buy a great big harness, new gear selector sensor etc, all i need is the one connector that connects to their module but they don't sell that separately. I'm not sure if there is going to be any real benefit using compushift... might be cool to adjust for a sooner lockup but i'm not sure. might be a great big hassle to tune too. Is there anybody using compushift with a a442 and has feedback?
other ideas? controllers to use?
Yeah, the stock tcu works fine standalone. Iirc it just needs temp and tps analog signals
I'm quoting from this thread: Haltech Control of the A442f
@PIP
sounds like you've been here before? are you talking about a stock diesel or gas TCU?
I did not hook up either temp signal circuit. From reading the FSM it sounds like ect1 was the "engine cold don't shift into OD" signal and ect2 was the "engine overheating fail-safe mode" signal. but as of now the temp signal doesn't seam to be an issue based on the code.
your cummins airbox would prob fit my build nicely too.
