I had to remove my valve body assembly from the transmission casing so I could swap the manual valve lever shaft, it connects the shifter linkage to the park neutral switch.
I was wondering if it is a must to replace the valve body gasket or can I reuse it because I did not separate the upper valve body from the lower valve body, only the valve body assembly from the transmission casing.
